H3 2006 4 wheel lock out problem
Old Nov 10, 2014 | 07:21 AM
marty22222's Avatar
Default H3 2006 4 wheel lock out problem
My H3 won't come out of 4 high. I tried backing up pushing buttons every way thinkable. I un hooked drive shaft and unplugged wire harness put drive shaft back in and it felt like it was out but 10 min of driving it went back in
Old Nov 10, 2014 | 07:27 AM
RKSmith163's Avatar
Cycle the buttons several times and make sure they are clean and not physically sticking. If that don't work, search Plastic Shift Fork and Actuator Motor. Good Luck
Old Nov 10, 2014 | 09:41 AM
marty22222's Avatar
If I take the front drive shaft out can I drive it until I can get it fixed?
Old Nov 10, 2014 | 10:21 AM
Bunger's Avatar
If you are truly stuck in 4-HI lock, then removing the front prop shaft is OK. Fix it ASAP though.
I'll be willing to bet that you have the plastic shift fork issue. GM stopped using the plastic shift fork and went with metal shift forks in later models.
ChevyChad
Feb 20, 2019 09:47 PM
chuffysplace
Aug 10, 2015 03:42 PM
FloridaFeMan
Sep 23, 2010 02:20 PM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
aziza z
Jun 16, 2008 10:19 PM
