Got another question
Old Sep 6, 2008 | 11:16 AM
Todd's Avatar
Default Got another question
I blew out an upper ball joint the other day and right now I am waiting on parts. I have the Hummer sitting on jack stands and the hug supported.
The question is... I have some play in that shaft. I know its not lined up perfectly because of the busted ball joint but will the slack go away after I replace the ball joint? I gotta replace the boot on that end so I gotta take it out and plan on doing that when I change the ball joints.
Any ideas what I should look for? Or things to worry about?[/align]
Old Sep 6, 2008 | 02:16 PM
ronb's Avatar
Default RE: Got another question
the shafts are made to go in/out to allow for suspension travel but there shouldn't be much play or rattling the other way.
While the upper ball joint is out it's an easy halfshaft change as the geared hub can be moved out of the way to get the shaft out. I saw you on the hummerx site as well as the hml, glad you got your problems sorted out. In case you don't already have these bookmarked, for technical questions try the hml knowledge base (many on the hml are hardcore h1 do-it-your-selfers):
http://www.HummerKnowledgeBase.com/H1.html
or Chuck's site has great articles with pictures and step by step instructions to do most anything hummer:
http://www.flashoffroad.com/humdefault.htm
I see you bought some of Eric's ball joints, a great deal as they are usually about $70 each.
Old Sep 6, 2008 | 03:52 PM
Todd's Avatar
Good deal. Thinking about it now I haveno load on thesuspension on that side and that is why it has slack in it.
Iordered some ball joints from BlueHummer.com buttheyhaven't made it in yet. I bought another boot from AutoZone so when all of my stuff gets here Iam going change both ball joints on thatside and replace mycv boot.
Old Sep 7, 2008 | 12:30 AM
Eric has the best deal going on ball joints but doesn't he only have the lowers?
Old Sep 7, 2008 | 12:10 PM
Todd's Avatar
Yeah heonly has lowers. I got my first set(uppers and lowers)from BlueHummer.com and I plan on buying extras from Eric.
ebfleetwood
Mar 17, 2013 12:38 AM
HEAVY HITTER
Nov 21, 2007 08:42 AM
MRDM1
Nov 14, 2007 04:04 PM
Voodoo
Mar 16, 2007 11:43 PM
byzance
Jul 6, 2006 05:07 PM
