GM Chrome Gas Door
Old May 5, 2010 | 10:48 AM
westerville's Avatar
Default GM Chrome Gas Door
We bought a H3 recently and she wants to add the chrome fuel door. We bought a gently used GM factory chrome door, but it doesn't have anything else with it (seems like there should be a ring). Are we missing a piece? Also, I was reading the installation instructions in the FAQ section and was wondering if I would really need to drill into the panel? Sorry if this question has been asked already. Thanks in advance for any responses.
Old May 5, 2010 | 12:14 PM
cnynctry's Avatar
There should be a paper template to show where to drill the holes. You can probable make your own my laying a piece of paper over the back of the door and marking the paper for the holes. Careful when you drill. So the door will be strait. Use the correct size drill bit so the holes wont be too big.
There is a small black trim ring that I thought was part of the door.
Old May 6, 2010 | 10:58 AM
marksteven's Avatar
Besides the template, there should also be 6 compression type nuts that you press into the holes you have to drill. This is what holds the fuel door in place. If you can't get those nuts from the dealer, the fuel door can't be mounted.
Old May 6, 2010 | 02:29 PM
Broken Halo's Avatar
There's also the black, plastic funnel shaped cap surround that replaces the stock piece.
Old May 6, 2010 | 08:17 PM
Thanks for the replies. It looks like we are missing a couple parts so I'll just order a new assembly. We basically have the chrome door and the screws in it. Thanks again for the help.
Old May 8, 2010 | 07:42 AM
ukpaul's Avatar
I had that problem. I bought a used one on ebay and it never had the carbon fibre looking trim ring. I hunted around a few dealers and eventually I got lucky. One of them had a complete used chrome door and all the fittings that someone had brought back because the chrome was peeling and sent them to me for nothing. I changed the chrome door out and everything was fine.
Good luck !
Old May 19, 2010 | 02:34 PM
fable123's Avatar
If you can't find what you need, I'm selling my assembled door with all the pieces for $75. My CL ad is attached below:
http://losangeles.craigslist.org/ant...744299388.html (auto parts)
Good luck!
ak47dennis
Nov 11, 2014 09:02 AM
mpukr9djsocr3
Jan 25, 2012 06:22 PM
finall
Jul 1, 2011 12:19 AM
jvorpahl
Mar 16, 2011 03:41 PM
BLK07H3
Dec 10, 2010 10:45 PM
