Fuse location
Old Jan 2, 2018 | 10:42 AM
Billsueb's Avatar
Default Fuse location
Can anyone tell me the fuse location for the exit lights on a2007 h3?
Old Jan 2, 2018 | 11:44 AM
I can do you one better. here is the owners manual for the 2007 H3
https://my.gm.com/content/dam/gmowne..._h3_owners.pdf
Old Jan 2, 2018 | 02:06 PM
Billsueb's Avatar
Not sure if you got my reply!Having a hard time navigating the forum,new at it!Wanted to thank you for your trouble.I have a manual but can't ID the exit light fuse!
Old Jan 2, 2018 | 02:19 PM
Are you talking about the interior lights, the ones when you open the door the lights come on?
If those are the lights, take a look in the manual, they can be turned on/off with the button by the headlight switch ring.
Old Jan 3, 2018 | 09:03 AM
Billsueb's Avatar
Switch is in off position.Lights have a dim glo! I have a parasitic draw and want to pull fuse,but cannot ID it!
Old Jan 5, 2018 | 12:42 PM
Billsueb's Avatar
Still looking for interior light fuse on 2007 h3.Fuse box diagram does not list it as such!Can anyone help me ID it?
Old Jan 6, 2018 | 05:03 AM
cucumber1949's Avatar
OP, I don't have a wiring diagram for the 2007 model, but attached are pages from the 2006 and 2008 manual showing the courtesy light circuit. There are some differences between the two years but the design of the circuits is similar, in that it doesn't look like it's a single fuse that powers just the courtesy lights, rather they are powered from the BCM as I read it. If I were looking for a parasitic draw, I would be pulling fuses one by one until I found the circuit and then start from there.
Old Jan 6, 2018 | 08:42 AM
BruceS's Avatar
Or if you think it’s the interior lights pull the bulbs
Old Jan 6, 2018 | 11:05 AM
Billsueb's Avatar
Thank you both for your response!The reason I was going to try the lights first is because the domes have a continuous glo.They are after market led.
Old Jan 6, 2018 | 11:39 AM
happythree's Avatar
drain at batt terminal on my 10 is 114 ma. you might check that first.
thats .114 amp after a minute of connecting meter.
