Front wire harness
Old Apr 21, 2011 | 01:31 PM
Deputyj's Avatar
Default Front wire harness
Does anyone know where I can find a front light wire harness or the main connector for the front lights? New or used doesn't matter. Trying to stay away from dealership and a 700. Dollar part. Thanks
Old May 2, 2011 | 10:09 PM
04colyZQ8's Avatar
Search Hummer Auto Parts
try these guys, to look up the part number you need, then go to GM parts direct there pricing is alot cheaper!! Or you may already no the part number, then just search below. For whole sale prices.
GM Parts Direct: Your direct source for Genuine GM Parts
Do you have a pic of the connector? What is wrong with yours? If you have a part number or picture I might be able to sort out a aftermarket one for you. I have a GM crimper set, and can possibly crimp to pins onto some wires.. depending on the connector.
Can you describe it to me?? female or male, 1 way 2 way 5 way etc..?
Old May 2, 2011 | 10:15 PM
04colyZQ8's Avatar
not sure what options you have but part number 24301070 might be the whole front harness for 186.00 Check it out for your self there are several options for front light harness.
Old May 2, 2011 | 10:30 PM
04colyZQ8's Avatar
does it by chance look like this?
Old May 3, 2011 | 06:17 AM
Deputyj's Avatar
No it is the male end of the pig tail. Water some how got in there and rotted away the little metal forks inside the pig tail.
Old May 3, 2011 | 03:26 PM
04colyZQ8's Avatar
Does the female that plugs into your male end at least look like this??
Old May 3, 2011 | 03:31 PM
04colyZQ8's Avatar
because if there is no damage to the plastic connector I can get news male pins. and if it the other end looks like that I might be-able to order in the one that mates with this.
Old May 4, 2011 | 05:24 AM
Deputyj's Avatar
Thanks I appreciate it. Just had it done at the dealership. 250.
Old May 4, 2011 | 02:05 PM
04colyZQ8's Avatar
hey no problem, and, at least it didn't cost you 700!!
Old Feb 4, 2013 | 07:01 PM
turboshaft's Avatar
Default LS3 conversion in a 2010 H3T
This is my first post in this forum and I am very interested in doing an LS3 conversion in a 2010 H3T. I see member 04colyZQ8 has done a number of posts on the subject and the information posted seems to be quite accurate as far as I can tell. I have conferred with my local GM dealer as to the parts to change and Current Performance told me they can modify the ECM wire harness and re-program the ECM for an LS3. If anyone has actually done one of these swaps and figured out how to comply with emissions I would be very interested in hearing from them about all the little things that have to be done to complete the swap. Thanks
Eddie Omegax
Feb 25, 2015 12:52 PM
gregaac
Jan 10, 2009 10:00 PM
bertoy
Apr 22, 2008 03:03 PM
TonyH3
Jan 14, 2008 10:45 AM
josh1899
Nov 17, 2007 04:53 PM
