Front upper shock bushes worn out at 30k miles ...
Old Jun 21, 2012 | 07:26 AM
Chad's Avatar
Default Front upper shock bushes worn out at 30k miles ...
Anyone else have early rubber bushing wear on there front shocks? Or is 30k miles normal for these?
I could hear this knocking noise in the front end and it was getting worse every drive ... so I jumped under the front and grabbed the shock and could move it back and forth and got the same noise.
At first I tried to tighten the top shock nut, but it has no thread left and is bottomed out. Upon removing the top nut, washer and shock rubber bush I then found a sleeve which slides inside the bushes. It's a metal sleeve and has worn a fair amount making it near egg shape.
The truck has never been off road and does mostly high way driving so I was quite surprised to see so much wear on what I thought was low miles.
So anyone else have these issues?
Also wanted to know if you can get a front shock bush kit maybe in nylathane or similar harder material ...
Thanx I'm advance guys
Chad
Old Jun 21, 2012 | 07:36 AM
Widespread Hummer's Avatar
Being on a number of forums a few years now, I have never read this issue before. Maybe they were never properly tightened to begin with leading to premature failure? Not sure about replacements but a little nosing around on the interenet and I'm sure you can find something. Maybe 4wheelparts.com or Trailduty.com
Old Jun 21, 2012 | 09:48 AM
Xlr8n's Avatar
+1 ^^
I'd have to guess your shock was not properly tightened form the factory which lead to early failure of the sleeve and bushings. That style of shock bushing is usually not an issue.
Old Jun 21, 2012 | 12:48 PM
alengman's Avatar
I had both front upper control arms go bad at 30,000 miles. It was covered under warranty though. Check and see if you are still covered.
Old Jun 22, 2012 | 03:34 AM
Chad's Avatar
I think you guys are probably right, they where probably never tightened enough from factory and its allowed the shock to float around and the bush to bash back and forth on its alignment hole.
Nolathane dosnt list a kit for it ... nor can I seen to find any after market kits for the shocks ...
anyway il keep poking around and see what I can find.
thanx guys
steveng
Jul 15, 2013 08:40 AM
CiB28
Oct 5, 2012 11:24 AM
Widespread Hummer
Mar 22, 2012 12:43 AM
Zip Tie Man5
22
Jun 6, 2011 10:54 PM
Bo
May 15, 2009 02:50 PM
