front locker info
Old Feb 12, 2008 | 08:22 PM
RealJeep's Avatar
Default RE: front locker info
The H3T will have a front locker when it comes out. We'll just have to wait and see who makes it.
Old Feb 14, 2008 | 01:19 AM
Sewie's Avatar
ORIGINAL: RealJeep
Pretty sure its an Eaton. I met a couple of the proving grounds engineers last fall on a Rubicon workday. They had a modified Colorado that had the H3 cast iron front diff with an e-locker.
Old Feb 14, 2008 | 12:14 PM
Desert Dan's Avatar
Once we figure out what diff and locker the H3T has then we need to find outif it will bolt in to the older H3's with the aluminum housing.
I'm looking to find a bolt-in cast ironhousing with gears and locker already installed. That way I can do the swap myself. Id' need the wiring set up and dash switch also.
Anybody else So. CA interested in doing the same?
Another option is buy the parts and find someone to set up the diff and locker.
If it won't bolt -in then I guess an Alpha with front and rear lockersis in the Future
Old Feb 14, 2008 | 12:29 PM
HumminNBoatin's Avatar
What is the Difference between the Aluminum and Cast Diffs??? Cant you I-5 Guys pull the guts out of your aluminum diffs and buy a Cast Iron Casing?
Old Feb 14, 2008 | 12:45 PM
Sewie's Avatar
ORIGINAL: HumminNBoatin
Oneis made ofaluminum, the other is made of cast iron.
The aluminum diffs are weak and are prone to housing flex and cracking. The CI diff in the current Alpha is the same size as the aluminum diffs in the I5 and will bolt right in. Just need to swap gears.
Old Feb 14, 2008 | 01:51 PM
So how much is the cast iron housing?
Old Feb 15, 2008 | 12:59 PM
Sewie's Avatar
Can't find a price on it, and when I had mine done I only paid the difference vs. the aluminum housing.
ALLROADSHOP
Jan 16, 2008 07:52 AM
ALLROADSHOP
Jan 14, 2008 01:13 PM
Brett
Nov 12, 2007 06:19 PM
merkur92
Jul 20, 2007 03:07 PM
Duke
Mar 22, 2006 06:42 PM
