Front leak- yellowish
Old Jan 16, 2010 | 09:41 PM
h2_32137's Avatar
Default Front leak- yellowish
Soooo.. I walked outside three days ago and there was a small puddle of "oil" from the front area of my H2. It appears to be a yellowy orange color. It's definitely not motor oil. I assume that it's probably from somewhere in the front end... I thought I would ask you guys before I went poking around as I have very little mechanical skills in this area. I will say that I got the local jiffy to look at it while they were changing my oil. They said they couldn't see where it was leaking from... Not that I am surprised. I do remember a similar smelling substance from my 1995 z71 back in the day. I had to replace my "ax-u-ate-or" as it was called. I did it myself and swore that I would never forget that smell. lol. This smells similar. This concludes my explanation. Anyone feel free to start wherever you see fit. What is it?
CB
Old Jan 16, 2010 | 11:51 PM
parabat's Avatar
Hello.
I just had the same problem. And it turned out to be the water pump. I would check that to see if it's the same for you.
Old Jan 17, 2010 | 05:25 PM
easy610's Avatar
When my dog used to do that rubbing his nose in it seemed to help....just a thought...
Old Jan 20, 2010 | 07:57 AM
Fred's Hummer's Avatar
Power steering fluid? Check the level.
Old Jan 22, 2010 | 11:08 PM
h2_32137's Avatar
Default Yup... Power steering flid indeed
Thanks! Power Steering Fluid was quite low. Not sure where the leak is but I'll keep adding. lol
CB
Old Jan 23, 2010 | 09:03 AM
CB, spray clean the underside of the PS pump and hoses. Use a degreaser and let it dry. Start the truck and move the steering from side to side a few times. Stop and look under again. Look for evidence of a leak, it just might be a loose fitting. If nothing found, look again after driving a few days. Hope you find it.
Old Jan 28, 2010 | 11:15 PM
h2_32137's Avatar
Default bearings
Thanks for the advice. I finally took the truck in to the shop. They replaced the bearings on the drivers side front wheel. Wheel was about to come off. lol. I sprayed the hoses etc too though as you stated. I think both problems are now solved. 500.00 bucks later. lol
CB
t_dog_lxi
Feb 3, 2012 01:45 PM
federicoiz
Nov 19, 2011 04:08 AM
PJ H2 SUT
Hummer H2 SUT
Sep 28, 2010 01:03 PM
Goinvertical
Jun 24, 2010 01:52 PM
RickLF
Jul 3, 2008 07:16 AM
