Front Hub Bearings
Old May 4, 2019 | 09:33 PM
wongsol's Avatar
Default Front Hub Bearings
I put a lot of miles on my H3 and have replaced each front hub at least twice. I DO buy budget hub assemblies and I realize the premium hubs with better bearings might be worth the price. I was wondering if these hubs are rebuildable, meaning, can I press out the bearings and replace THOSE with premium bearings instead of replacing the whole assembly.
TIA
Old May 5, 2019 | 07:21 PM
You will have to spend money on the bearings, seals, and you need the proper equipment to replace, and you also need to make sure there is no damage to the hub.
I think you need mental help, just like this guy needs, for a $50.00 brand new hub replacement:
Old May 5, 2019 | 11:18 PM
wongsol's Avatar
I work in a shop that is equipped....
Was that a necessary comment? Good hubs aren't cheap, I already said that I was buying "budget" minded hubs.....
Old May 6, 2019 | 01:20 AM
happythree's Avatar
you must enjoy the work. seriously,i did timken on a wj jeep and it was not fun.got 146000 on originals.
if its around at 300000 i wont be. timken at $150 a pair is cheap...
Old May 6, 2019 | 07:14 AM
wongsol's Avatar
I do like the work (motorcycle mechanic) and I do most of my own work sans transmission rebuilds. I get the fact that the cost for a replacement hub is inexpensive. I will replace the bad hub and keep it and play around with it instead of tossing it in the scrap metal bin at work. I'll update the members if I'm successful.
Old May 6, 2019 | 08:56 AM
talusfan's Avatar
Buy oem hubs, yes they are more expensive or you can keep replacing cheap hubs until you get tired of it.
Old May 6, 2019 | 11:39 AM
atvspeed4's Avatar
And PLEASE use a damn torque wrench on the axle nut...
Not using one will destroy a hub prematurely no question.
Old May 6, 2019 | 11:54 AM
happythree's Avatar
why is that?
Old May 6, 2019 | 12:37 PM
H3Luxembourg's Avatar
Just get OEMs or good aftermarket hubs, no junk, it's for your security ! I think 200 or 250 bucks are not too much to spend in life for a secure drive.
Old May 6, 2019 | 02:28 PM
wongsol's Avatar
https://www.hummerforums.com/forum/h...pecs-h3-32901/
