Front end shake
Old Sep 28, 2012 | 11:42 AM
Deputyj's Avatar
Default Front end shake
My 07 H3 has a rattle in the front end that stops when I get over 40 mph. Thought it might be an alignment problem because it has a shake also. Tires were all balanced, four wheel alignment and tire rotation completed. Chassis and gaskets were all checked no leeks found. Drive shaft also checked. Any ideas?
Old Sep 28, 2012 | 05:17 PM
Happy Hummer's Avatar
Front diff mounts or rack & pin...
Chris
Old Sep 30, 2012 | 08:19 AM
Widespread Hummer's Avatar
You may want to jack up the front end and grab the tire at 3 oclock and 9 oclock and see if you can shake it back and forth. You may find a thread or 2 using the search function.
Old Sep 30, 2012 | 08:54 AM
Smittro's Avatar
Bad rack, bad rack mount bushings, bad tie rod ends, bad ball joints, warped rotors, bad cv joint, bad wheel bearings, wheel weight fell off, ect, ect.
Any one or all of these can cause front end wobble.
Old Oct 4, 2012 | 02:13 AM
mavrk73's Avatar
Ever here of "Hunner" on this forum and others, this guy seems to know what he is talking about, fabricates and sells some badass inexpensive hummer parts, when they're available (sell out fast!) He has a bunch of threads on the weak front ends and what he did to fix the problem, plus a bunch of other things for the H3/H3T's.
Raffi76
26
Feb 18, 2015 03:20 PM
marine
19
Oct 18, 2011 08:23 AM
tyler durden
Oct 5, 2011 01:36 PM
H3OHIO
Aug 13, 2009 10:34 AM
kuda007
Nov 26, 2006 12:52 AM
