Front End Rattle After Off-roading
Old Apr 7, 2012 | 09:21 AM
Ganza_Clark's Avatar
Default Front End Rattle After Off-roading
My front passenger side wheel rattles during off pedal...I mean 'coasting'.
It only rattles when off-throttle. If I step on the gas even very little amount, it' doesn't.
I found the crack at the differential mount which is on the crossmember...so I changed it, but it wasn't a culprit.
Check this out.
Front Rattle - YouTube
My next suspect is a half shaft, maybe the next one will be a diff.
What do you guys think? Hopefully everyone could understand my English.
Thanks.
Old Apr 21, 2012 | 07:18 AM
sandkiwi's Avatar
Sorry to hear that....check tie rod, then propellor shaft.....ive broken both of these......good luck
Old Apr 22, 2012 | 06:48 PM
Khrome's Avatar
Check your skid plates.
Old Apr 22, 2012 | 09:13 PM
nlhummer's Avatar
lug nuts torqued to spec?
Old Apr 23, 2012 | 05:37 AM
Widespread Hummer's Avatar
I watched the video about 10 times and I'm having a hard time putting that noise to the tire. It seems more dependent on engine rpm than wheel spin. Have you chekced everything that could be loose like skid plates and heat shield?
Good luck and please post your outcome.
Old Apr 23, 2012 | 07:16 AM
I tried throttle even without the wheel, it still rattles. The rattle sound is coming from the 'thin metal plate' which is right beside of the rotor...but it's obvious that my outboard cv makes the vibration. I found it almost stuck when I disassembled it. Now I'm waiting for my new cv from RCV, but no one knows the result. I hope that will be an end.
Old Apr 28, 2012 | 10:29 PM
It turns out the thing is front diff damage, probably the ring and pinion.
I'm waiting for the parts.
dmb7280
Nov 16, 2014 03:38 PM
PhenyxH3
Oct 29, 2010 03:23 PM
haiminger
Jan 24, 2008 11:48 AM
07TacticalH3
Nov 10, 2007 05:46 PM
gericoshep
Oct 17, 2007 06:32 PM
