front differential top up
Old Oct 13, 2007 | 06:29 PM
dizzy's Avatar
Default front differential top up
Hey guys. I was checking the differential fluid level today and I know the owners manual says the level should be half inch below the bottom of the fill plug when cold. If I put my baby finger in there, I cannot put it in far enough to get to the level. Should I just fill till fluid starts to come out the hole that way I will know it is full? Does it matter what fluid I use just for a top up as long as it is 75-90 synthetic? Thanks in advance.
Old Oct 14, 2007 | 12:33 AM
dizzy's Avatar
Default RE: front differential top up
While tonight I topped up the front diff. with castrol syntec 75-90. Would anyone have a manual that would show the torque for the fill plug on the diff? For now I torqued it at 25ft/lbs. Thanks
Old Oct 14, 2007 | 10:03 AM
Muddydawg75's Avatar
Just snug the plug up.... tight is tight... it really doesn't need to be torqued.
I fill mine until it comes out the hole.... about 2 quarts for the back.... and about 1 3/4 for the front. (from empty)
One small piece of advice.... always make sure you can get the fill plug out before you remove the drain plug.
Old Oct 14, 2007 | 06:34 PM
dizzy's Avatar
This time I just topped it up. I don,t know when it was looked at last but it took almost half bottle. I will keep an eye on it now. i have only owned this H2 for about 2 months .I love it.
Old Oct 14, 2007 | 07:56 PM
hilljob26's Avatar
every diff is about the same,fill it up till it comes out the hole,then just give the wrench a good grunt,like muddy said,tight is tight,theres no load on this so torque shouldnt really applyas long as its tight
rijowysock
Mar 7, 2013 07:57 PM
upholstryguy
Jun 17, 2010 09:35 AM
Nxsov180db
Jun 1, 2008 02:47 PM
HingHum
Jun 13, 2007 07:12 PM
vinceau911
Dec 19, 2006 05:08 AM
