Front Diff Leak
Old Mar 19, 2010 | 08:52 PM
Goinvertical's Avatar
Default Front Diff Leak
I recently replaced the main shaft seal in the front diffrential gear in my 2003 H2 with 90k miles however below the seal it is "wet" with gear oil. I've heard this might not be a good sign but can someone explain what is going on and what the long term prognosis?
Old Mar 19, 2010 | 09:03 PM
VegasGuy's Avatar
It should not still be leaking if you replaced the seal (with the correct seal). Did you inspect the shaft for nicks or other signs of damage?
Old Mar 23, 2010 | 01:21 PM
HumminNBoatin's Avatar
I would clean it with break parts cleaner and check it regularly to make sure you are not seeing residual oil from before your repair.
Old Mar 23, 2010 | 01:43 PM
Hummeron37s's Avatar
or clean it and put in black light dye and check it regularly with a black light.
Old Mar 24, 2010 | 08:25 AM
Thanks fir the comments. I did confirm I installed the correct seal and inspected the shaft and case before installation. In addition, I confirmen the breather line was not obstructed causing a pressure build up in the gear. Still, just today, I have a small drip of gear oil directly under the shaft seal.
Old Mar 24, 2010 | 08:35 AM
Sounds like you need a "do over" lol
Old Jun 23, 2010 | 07:56 PM
Smile
Well, it turned out to be the o-ring seal on the bearing adjustment part of the diff. a 2.10 fix.
Old Jun 24, 2010 | 01:52 PM
Pulling your hair out for $2.10. Got to love it. Glad you figured it out.
mthoodh3
Dec 5, 2016 10:53 AM
Jefferyg63
Jul 8, 2014 03:32 PM
cobra
Dec 13, 2013 08:53 PM
06lugnut
Dec 28, 2012 05:08 PM
PJ H2 SUT
Hummer H2 SUT
Sep 28, 2010 01:03 PM
