Fan clutch replacement
Old Mar 21, 2015 | 07:46 PM
joenuzz's Avatar
Default Fan clutch replacement
I need to replace the fan clutch on my 97. Can this be done without removing the cooling stack? It looks like I can unbolt the fan from the clutch then unbolt the clutch shaft from the pulley. Then get the fan out and finagle the clutch out through the top. Is this true?
Old Mar 22, 2015 | 08:34 AM
joenuzz's Avatar
We'll never mind. I got both the fan and the clutch out without removing the cooling stack. I had to remove the idler pulley assembly, the water pump pulley, and separate the fan from the clutch. You have to finagle the fan out through the upper passenger side of the motor. Same with the clutch.
Waelhilal
Sep 16, 2014 08:26 AM
Alex2012
Jun 4, 2013 02:58 AM
rsc
Sep 12, 2011 09:40 AM
CHP
Jun 8, 2011 07:55 AM
HummerGuy
18
May 5, 2007 02:27 AM
