EU-modification, rear lights
Old Mar 20, 2011 | 05:32 PM
duco's Avatar
Or well, I thought the break signal and the turn signal was the same wire... as it was connected to the same bulb.
I really hope it's not, then it should just be a 15-minute job.
Old Mar 20, 2011 | 06:19 PM
Broken Halo's Avatar
The turn signal and brake light IS the same wire. It is a two filament bulb with three wires. 1 wire is the ground, 1 wire feeds + to the tail lamp filament and 1 wire feeds + to the turn signal/brake light filament. When the turn signal is activated at the same time the brake light is on, that filament cycles off and on. Of coarse this is assuming you have a 2 bulb system consisting of a backup lamp and a tail, brake/turn lamp. If you have a 3 bulb system (back up, tail lamp/brake, and yellow turn signal), then you DO have a separate wire for the turn signal and brake light.
Jogi
Jun 9, 2014 02:03 PM
H3Traverse
May 9, 2010 08:03 PM
TINKED
24
Jan 23, 2008 09:00 AM
syphon
Jan 2, 2008 01:04 AM
Fireman
Jul 27, 2006 06:18 PM
