Entered sand dunes...left with hot air conditioning...HELP!!
Old Jul 16, 2013 | 09:17 PM
AutoRoc's Avatar
Default Entered sand dunes...left with hot air conditioning...HELP!!
So I went off roading at Silver Lake sand dunes... We ran the A/C every now and then, it was working great.. I never got air under the wheels but We hit some pretty rough sand whoops. Did I break a line? Crack a major part of the system? I put a shot of green dye in the system and half a can of Arctic Air and that got the compressor cycling... the air coming out of the vents feels wet, not cold and dehimidified like it should. There is NO water puddle anywhere while idling, that is odd...
The front mounted condensor has a wetness on the passrnger side, possibly cracked? Should that EVER be wet externally? The top/low pressure line is cold while the system cycles.
Looking for a diagram of the system and its parts.. Thanks
Old Jul 17, 2013 | 07:38 AM
If it is wet on a dry day, then it appears to be the condenser. Do you have goggles and a uv light?
Old Jul 18, 2013 | 05:37 AM
AutoRoc's Avatar
I think I have the goggles still from years back..
Old Sep 19, 2017 | 10:28 PM
Dionkraft's Avatar
You need to put some AC gauges on it to get some readings but if you did fill it up and now it works..I think condenser is damaged.
Old Sep 20, 2017 | 08:55 AM
We do not need to be digging up 4 YEAR OLD threads to make suggestions to people who are no longer here. Please avoid necrobumping.
https://www.hummerforums.com/forum/n...bumping-23220/
Old Sep 21, 2017 | 07:44 AM
AutoRoc's Avatar
My AC problem was a bad expansion valve. My pressures were all perfect and a dealer told me expansion valve. I installed the $50 part myself and had a local shop recharge it for $65. Problem solved. Dealer quoted well over $600 if I remember right..
Doc Olds
20
Jun 18, 2013 12:53 PM
phazer42
94
Oct 28, 2008 09:31 AM
HummerGuy
Meets, Events, and Shows
103
Jul 2, 2008 11:11 AM
hotrodthom
Jul 13, 2007 11:59 AM
qatar
25
Jan 18, 2007 09:54 PM
