Engine noise.
Old Aug 6, 2007 | 03:57 PM
Muddydawg75's Avatar
Default RE: Engine noise.
Does it tap faster when you rev the motor?
Old Aug 15, 2007 | 10:01 PM
a04h2's Avatar
change your oil, oil breaks down even though it doesn't have mileage
Old Aug 18, 2007 | 08:15 AM
Sugardaddy's Avatar
Already!! It's only been a year!!
Old Aug 18, 2007 | 08:11 PM
Jet Mech's Avatar
Well let's assume it's not a valve tap. How about a serpentine belt tensioner or a very small exhaust leak. I've had both on a Chevy truck and would have sworn they were valve taps. The exhaust leak would only show up when it was cold outside but would disappear when the truck warmed up. The belt tensioner was a common problem on several GM vehicles but I thought they had that ironed out already. Anyway, just a couple ideas. Either way, it should be warranted. Good luck.
Old Aug 21, 2007 | 11:07 PM
a04h2's Avatar
YOU'RE STILL UNDER WARRANTY, TRY TO BLOW IT UP, I BET IT WON'T
Old Aug 22, 2007 | 08:55 AM
I'm going with exhaust leak, loose collectorbolts at the pipe flange. The exhaust manifold head bolts rarely get loose, but it has happened. Crud, you could even have a crack in the pipes somewhere. Hello trip to the dealership. [:'(]
hulkh3
Sep 12, 2012 08:02 AM
BabyTank
Oct 12, 2011 06:07 AM
jm4490
Dec 19, 2006 04:52 PM
carissa
Apr 18, 2006 12:48 AM
