Electric fans or lower temp clutch/thermostat.
Old Jun 29, 2018 | 12:16 PM
amrg's Avatar
I thought Id add, the clutch fan on the H3 is really good for the application. There is a reason the tbss with the ls2 didnt come with efans. The main problen is the radiator, it has too small of a surface area (5.3 trucks have 28" wide rads while the H3 is only 22.5").
If you want to cool it more get a thicker rad, RD or griffin have 2 core radiators for the H3 (Im using griffin). It is very thick.
if you really want to change the clutch fan to an efan, get one of those new camaro brushless fans and adapt it to the H3 radiator. You cant get any stronger.
Old Jul 1, 2018 | 08:54 AM
BruceS's Avatar
I have an 07 h3 with i5 which has thermostat on bottom. I gutted stock thermostat and put an inline thermostat up on top hose. I run 180 and have a spal 16” pusher fan on controller which kicks on with ac and higher temps. Typically keeps engine below 190 with same ambient temps you are talking about. I live in middle TN and it gets hot here.
Old Jul 1, 2018 | 11:18 AM
LT1 POWR's Avatar
So I take it there is no lower temp stock replacement thermostat? Anyone try a severe duty fan clutch, something that locks up more or has a lower temp. Is there a Hayden part # for the stock fan?
Old Jul 1, 2018 | 07:19 PM
Ordieh's Avatar
A lower temp thermostat will not do a thing for a system that can't do the job!
Old Jul 2, 2018 | 02:31 AM
amrg's Avatar
What he said. A lower thermo will only drop temps if your current cooling system has the ability to drop to said temps. Otherwise it will only slow down your engine from reaching operating temps
Hands
Aug 17, 2020 07:32 PM
Albmark
Aug 28, 2019 09:57 AM
shiksa
Aug 6, 2018 11:56 AM
Shauna Makuch
19
Aug 22, 2017 04:39 PM
mtauseefsa
Sep 24, 2010 01:53 PM
