Dvd no power
Old May 10, 2016 | 07:47 PM
hummin along's Avatar
Default Dvd no power
Drivers side DVD player will not work. Is this a common problem...with and easy check and fix? Just asking before I rip things apart. Thanks
Old May 11, 2016 | 10:41 AM
650Hawk's Avatar
??? As opposed to the passenger side DVD player? ???
Old May 11, 2016 | 07:21 PM
Uh........yeah.
Old May 12, 2016 | 07:58 AM
650Hawk's Avatar
Well, since there's only 1 DVD player, I assume that you mean the driver side "speaker" doesn't work, right? Does it work with the radio? If so, then your stereo head unit is shot and needs to be replaced. If not, then start by pulling the door panel to check the wiring at the speaker. If that's ok, then you'll need to pull the center dash panel (where the head unit is) to access the back of the stereo head unit & check the wiring at that point.
Old May 12, 2016 | 06:12 PM
Broken Halo's Avatar
I guess I'll clear up the issue since this will just keep going back and forth. He's got rear, head rest mounted DVD players....'driver' & 'passenger'.
Old May 12, 2016 | 06:59 PM
Yes Broken Halo,
Took the drivers rear seat cover off...all good. I traced the two wires. Why the ever routed them the way they did one will never know. It is going into the seat slide track and simply pulled out. I have the end with a connector on it. New problem is this wire is connected to something on the bottom of the back of the center console. The wire that pulled out of the connector will go into this console about 5". So now I will search on how to remove that. It does not look like fun!
Old May 13, 2016 | 06:17 AM
Pic of wire end. Should be an easy fix once I figure out the console removal.
Attached Thumbnails Dvd no power-img_20160513_070627175.jpg   Dvd no power-img_20160513_070758068.jpg
Old May 13, 2016 | 08:32 AM
650Hawk's Avatar
Wow, sorry. Now I feel really stupid. Glad you got it figured out. Console removal shouldn't be too hard.
Old May 13, 2016 | 12:14 PM
I can not find a good pic of an exploded view of the console. That would be a big help.
Old May 14, 2016 | 12:40 PM
Fixed!
I just took out the rear bolts holding the seat down, reached in under the console and pulled out wires. Because GM decided to run the wire in my electric seat track, when someone wanted the seat as far forward as one could get it......it pulled the wires apart. I simply just reconnected and both DVD players worked perfectly. All this was done WITHOUT removing the console. My first sticky!
Attached Thumbnails Dvd no power-img_20160514_121909908.jpg   Dvd no power-img_20160514_121841856.jpg
