driver window and power door locks gone bad
Old Nov 18, 2010 | 12:17 PM
jhpulley's Avatar
Default driver window and power door locks gone bad
i have a 2007 H3 at the same time the drivers power window and the power door locks stopped working..if you try the remote you can hear the relay clicking and see the lights flash ..and the other windows are working... seems as though they are linked in some way .. can anyone please help ... thanks
Old Nov 18, 2010 | 03:29 PM
drtom's Avatar
Banned
Default quik guess
wires going into door, common supply?
does anything on door work?
ill look asap
Old Nov 18, 2010 | 04:12 PM
bheff's Avatar
I had the same happen to me. I just (today) replaced the entire driver side window/lock controls. Works perfectly. And the key fob now locks and unlocks like it is supposed to as well.
Old Nov 18, 2010 | 08:16 PM
jhpulley's Avatar
passenger and rear windows work from driver door...nothing else..thanks
Old Nov 18, 2010 | 08:42 PM
bheff's Avatar
Yep, everything worked fine except the driver window, locks, and key fob. Like I said, I replaced to whole unit and works like a champ. There are a several threads going if you search there might be a few things you could try.
Old Nov 18, 2010 | 09:37 PM
jhpulley's Avatar
thanks...did you get it from the dealer ? very pricey ?
Old Nov 18, 2010 | 10:30 PM
drtom's Avatar
Banned
i had similar problem in pontiac, broken wire, feed 12v. i jumped it, fixed. you might spend some time checking first. edit, i remember,it did some stuff on other door but not driver. i jumpered a wire from right door underr dash to left door. not elegant but its my work van. thse point is there can be 2 feeds to one door. im bettin its not the switches!!
Old Nov 25, 2010 | 03:09 PM
ted78's Avatar
Is this a common problem? I had same issue.
Old Nov 27, 2010 | 12:21 AM
jhpulley's Avatar
seems like it is , i have heard of several with this problem.
lostsoul77
Nov 27, 2023 09:19 AM
Alukavi
Dec 28, 2020 09:22 AM
potroast
Dec 14, 2013 11:27 AM
sg27
Dec 11, 2010 10:27 PM
