Driver side sag
Old Jan 5, 2009 | 12:42 AM
johnnyballistic's Avatar
Default Driver side sag
I have a lifted 03 H2. The rear sags on the left side and on the front driver side. I think it is the rear coil spring. Any other ideas?
Old Jan 5, 2009 | 10:18 AM
tomp's Avatar
Default RE: Driver side sag
Mine did same thing...
It's due to several things:
-gas tank on left
-driver on left
-steering column on left
-front right wheel is drive-wheel so it throws weight to rear-left when accelerating
Couple of things to address it:
-new coil springs
-add airlift air bags with seperate valves for independant control
-swap coil springs
I did the air bags and run 30#s psion the left side and 15#s psi on the right. The cost was only $90 and now when I take off from a dead stop and is so much more steady!
Old Jan 5, 2009 | 10:26 AM
tomp's Avatar
One other note...keep in mind that the factory shocks were 300psi each so they provided some "spring rate assistance" to the rear coils. Most likely, you changed these out to match the lift kit and this would have speeded up the process of wearing out your left coil spring.
Old Jan 6, 2009 | 04:52 PM
solarflare's Avatar
You may also want to check your torsion bars.....and adjust the keys. Depending on how many miles you have, you may have a torsion bar on the driver's side that is a little more worn out, and will need to be adjusted up.
boardergrl
May 12, 2011 07:37 PM
BearClawz
Nov 20, 2010 06:32 AM
LooseMoose
Aug 27, 2010 10:29 PM
NJTEX
Jul 28, 2009 01:17 PM
tzhmmr
Jan 13, 2009 08:22 AM
