Display gauges without function H2
Old May 7, 2017 | 03:14 AM
Senegambie's Avatar
Default Display gauges without function H2
My H2 SUT display gauges speedometer and odometer stopped to fonction. Display light and directions sign and engin checklight still works. What should I do. Because I m in Senegal and here is no GM representative.
Old May 8, 2017 | 02:13 PM
Bunger's Avatar
I'm no H2 expert but I think the dash gauges are run by servo's. You could have a couple of servo's that have failed.
Old May 9, 2017 | 03:03 AM
Senegambie's Avatar
thanks for your answer bot odometer don't work also.
Old May 9, 2017 | 04:43 AM
E-dragon's Avatar
Check ALL your fuses ( and I do mean ALL ), GM in their infinite wisdom did not list all the connections to all the fuses. If no joy, then personally I'd just pull it and send it in there are a few small companies that do gauges and they will go through and replace what needs to be. Also a lot will swap out the lights for leds ( colored or white ) usually for a bit over 100$.
BTW you can still use the truck without the cluster in...
jeremiahpreston
Jan 10, 2009 08:22 PM
jrs2005
Apr 21, 2008 09:52 AM
Nxsov180db
Apr 17, 2008 04:51 AM
Dennis
May 15, 2007 12:54 PM
littlehummerboy
May 10, 2007 08:58 PM
