Disengaging axles for towing behind motor coach
Old Apr 14, 2015 | 03:59 PM
ReRun0007's Avatar
Default Disengaging axles for towing behind motor coach
2007 H3x, white, 75K mi, a real head turner ---- I have lost the capability to disengage the drive axles by depressing the 2 wheel and 4 wheel buttons for 10 seconds and illuminating the red "N" lite on the dash between the 2 buttons.
What's required to restore this capability and approx cost?
Richard The Villages, FL 32162 pls reply via e-mail to rdi0007@yahoo.com
Old Apr 15, 2015 | 11:04 AM
You might want to try shifting the T Case into Lo Lock, drive for a short distance, like 30-50 ft., then shift back up to High (review the owner's manual) and then see if it will go into Neutral following the steps in the manual.
Old Apr 16, 2015 | 03:38 PM
CurtisP87's Avatar
^^ that.
Does your truck shift into 4hi lock and 4lo with no problems? Sounds like you could have the shift fork issue, but correct me if im wrong someone, shouldnt his 2007 have the metal fork...?
If your Tcase shifts with no problems and what doc suggested doesnt help, thats a real head scratcher....good luck, keep us posted.
Old Apr 17, 2015 | 03:20 PM
ReRun0007's Avatar
Default Cannot disengage axles on '07 H3x for towing behind motor coach
Doc Olds suggested procedure above worked !!!!!!! thx to Doc -- TUVM !!
I did exactly as he suggested and the red "N" lite comes on in 10 sec s just like it's designed to do following the procedures in the owner's manual.
Just to be sure I tried the normal procedure in the owner's manual 1 hr later and the axles disengaged just like they are designed to do.
The only difference I notice is when engaging the axles after they have been disengaged for towing I'm experiencing a louder "clunk" than before. Sounds like something needs grease????? Any ideas to convert the "clunk" back to a quieter "click" when the Hummer was new????
THANKS AGAIN DOC !!!!!!!!!!!!!!!!!!!!!!!!
Richard Ingram rdi0007@yahoo.com
Old Apr 17, 2015 | 04:59 PM
happythree's Avatar
i think its good to at times shift to every combination possible just to exercize the mechanisim. i use my back field and dig up the turf a little.
Old Apr 26, 2015 | 12:52 PM
ReRun0007's Avatar
no response so far on how to eliminate the "clunk" noise when re engaging axles after towing behind motor coach. I'd like to hear a "click" instead of a hard "clunk". Maybe something needs grease? If so, where?
ReRun0007
Sep 30, 2014 01:26 PM
joenuzz
Jun 25, 2012 03:14 AM
onetexasoldman
Dec 31, 2011 04:59 PM
tallbiker66
Dec 2, 2010 10:15 PM
HummerGuy
Oct 18, 2006 05:01 PM
