differential juice change
Old Mar 7, 2015 | 11:19 PM
happythree's Avatar
Default differential juice change
the rear couldnt be easier. the front a little harder to get at the filler hole.
i ran a 1/4 in tubing horizontally from the hole and then all the way up to the rad top area, about 3 feet. it was ez to stand straight up and push the juice into the clear tubing ,checking after the first qt till it started to overflow.
both ends in no rush was about 45 min. i kept the juice inside nice and warm till the job was done.
next the t case,ez,,,then the tranny,,,oh no! do you guys change the filter gasket ring or reuse the old one. looks like it could be a bugger to change?
Old Mar 8, 2015 | 08:56 PM
BlueH3's Avatar
Great to know tips thanks - at what mileage should the diffs be changed with no offroad 4wheelin'? What mileage you change at?
Old Mar 8, 2015 | 09:22 PM
happythree's Avatar
the book will tell you one thing. i did mine at 53000. cheap insurance, all lubes!
Old Mar 9, 2015 | 06:33 AM
Twozero1's Avatar
Just did the same thing with the front diff fill. Bought truck with 65000 beginning of January did diffs last week with 68000 and it was definitely never changed. New TC motor was put in but I didn't change TC fluid yet.
Old Mar 9, 2015 | 07:23 PM
skeeter's Avatar
You can buy a fluid pump at harbor freight for less than $20, and it is whole lot easier to do from the bottom of the truck
Old Mar 10, 2015 | 03:29 AM
happythree's Avatar
yeah but no pump needed and the $20 buys the juice. cant be ezer than standing up and squeezing the bottle!!
and,,,i may never need the pump again!
now help me with my coolant leak!
Old Mar 10, 2015 | 10:40 AM
jonnieh3's Avatar
What did you use for "The Juice"
Old Mar 10, 2015 | 06:05 PM
skeeter's Avatar
you will need it again unless you plan on selling the vehicle soon.
the coolant leak is more than likely the radiator. they have a tendency to crack and leak, other than that I have only replaced the water pump for leaking
Old Mar 10, 2015 | 08:02 PM
happythree's Avatar
what the book calls for,,,75/90 synthetic gear lube
No more Jeeps
Jul 2, 2020 03:37 PM
ftc-garage
Dec 29, 2012 08:38 AM
Christian.
Jul 2, 2012 08:20 AM
dwaxman1
Apr 27, 2008 08:18 AM
HummerGuy
20
Dec 22, 2006 02:14 PM
