Depressurization procedure H2 air springs
Old Dec 9, 2009 | 04:52 AM
marcus133's Avatar
Default Depressurization procedure H2 air springs
As far as I know you must have a scan tool to do the depressurization procedure of the air springs on a H2. Is this true? Does anyone know another way to do this?
This is because I will change the air springs because of a small leak.
Old Dec 9, 2009 | 11:30 AM
calif phil's Avatar
I would think you should be able to disconnect the ride height sensor and manually move the sensor to delete the air pressure. Put some jack stands under the rear bumper so it wont drop on you.
Old Dec 9, 2009 | 01:23 PM
BIGT2148's Avatar
If its turned off, the truck should be depressurized anyways.
Old Dec 9, 2009 | 03:00 PM
calif phil's Avatar
The bags will still be under pressure even with the truck turned off.
Old Dec 16, 2009 | 10:06 PM
tnbeast's Avatar
I just did this on mine and I know people will complain but I just cut them with a knife while it is in the air on the rack since it will lower quickly if not careful. Do NOT do this while it is sitting on the tires on the ground. There is alot of pressure in the bags but not a blasting pressure
Old Dec 18, 2009 | 03:50 PM
cipgramus's Avatar
Good post. I appreciate it.
Many thanks to ur post. I love it.
jvorpahl
29
Jan 13, 2014 03:31 PM
MAXIMA_818
19
Nov 12, 2012 09:33 PM
chapel321
Oct 31, 2008 11:42 AM
TacticalH3
Sep 21, 2007 06:36 AM
brachilius
May 9, 2007 02:14 PM
