dead battery
Old Oct 21, 2012 | 10:34 AM
amy11's Avatar
Default dead battery
So has anyone had there battery go dead after parking the H3 for a few hours or over night. All ready changed battery. THought that might have been it. No luck. Next we pulled radio fuse because we read some have problem with Cd player. No luck there. looking for suggestion before it goes to shop. 09 H3 3.7 motor.
Old Oct 21, 2012 | 04:35 PM
RKSmith163's Avatar
I remember a while back there was a problem with the Onstar module draining batteries. The fuse for that is on the positive battery cable I think. You stated that you had already replaced the battery.
Old Oct 21, 2012 | 06:59 PM
happythree's Avatar
Normal drain,I read here and checked,is 110 ma.
If you monitor the current with an ammeter you can pull fuses till you find the bad circuit.
Yours is probably a few amps or more.
Volts after starting go up to 15 then drop to appx 14 if the charger is working. that could be a problem.
Old Oct 21, 2012 | 10:19 PM
How long have you owned it? Since new? IF not there may be some kind of aftermarket electronic device sucking power because it was improperly installed to a constant power source.
Do you have an aftermarket alarm or remote starter? If so, REMOVE IT and I bet your battery drain will go away.
If not, then follow the trail by turning off everything, pop the hood, grab a multi meter and wait for about 5 minutes. Then start testing each fuse to see what is still on.
Old Oct 22, 2012 | 07:39 AM
amy11's Avatar
No aftermarket stuff installed. I have heard about the onstar problem. We are gonna try the multimeter when we get back. Thanks for the suggestions guy. Its a ver frustrating problem. It will kill the Yellow top Optima in Just a few hours. So its got to be a big draw.
Old Oct 22, 2012 | 09:40 AM
BERULAKIDE's Avatar
Hey, did you check the battery cables? Mine was doing that and even had to pay a cab for a boost once because it was wiggling loose somehow. I heard there is an issue with the cables or clamp and i had a no start episode and i wiggled the clamp and it spun about a quarter turn and tightened up and bingo haven't had a.problem since. So unhooked it and turn it a quarter or half turn and tighten up. May find that works if you are really lucky.
Old Oct 22, 2012 | 05:19 PM
amy11's Avatar
wish it was that easy.... already changed battery. terminals all seem good.
Old Oct 22, 2012 | 11:12 PM
Happy Hummer's Avatar
So the prob is fixed?
Chris
Old Oct 23, 2012 | 07:31 AM
amy11's Avatar
no not yet. out of town till weekend. will check it this weekend.
Old Oct 28, 2012 | 06:08 PM
amy11's Avatar
So I checked battery seems it it 5.55 millamp draw. I pulled every fuse one by one. Nothing changes. Even pulled onstar fuse. BAttery is still going dead. Anyone got any suggestion.
