Dashboard Vents Not Working
Old Oct 10, 2009 | 11:47 PM
desiyaar1's Avatar
Default Dashboard Vents Not Working
This is going to come as a shock to most of you, but there is something ELSE wrong with my '05 H2 with 34k miles.
The only vents that work are the defroster vents (ones that blow onto the bottom of the windshield).
None of the other vents work. Not sure if its related, but whenever I turn the car off, a groan comes from the dash like someone is punching a senior citizen...
Any suggestions as to what it could be?
Old Oct 11, 2009 | 11:13 PM
VegasGuy's Avatar
An air vent control valve that is binding? Many years ago I guy I knew had a Chevy wagon that had some kind of automatic vent control. It was deformed and it bound. Instead of groaning it let out a loud bang when it would finally close.
Old Nov 27, 2009 | 10:43 PM
BIGT2148's Avatar
check the vacuum system. Sounds like a hose has come loose. Just fix where it came loose and she should be fixed.
Old Nov 28, 2009 | 09:42 AM
calif phil's Avatar
I doubt they are vacuum operated any more. Most use small electric motors to control the air flow and the temp blend door. If you can loacte the sound I bet you will find a small black box with stripped grears in it. They are not very expensive and not too hard to change if you can reach it. Most mount with two screws and one electrical plug.
JensH2
Sep 14, 2025 08:52 AM
TxHummer07
Mar 22, 2015 11:02 AM
gaspower
Feb 2, 2013 03:22 PM
Dennis
May 14, 2007 03:15 AM
HummerGuy
27
Apr 3, 2007 02:59 AM
