Dash Dimmer Switch.
Old Feb 4, 2008 | 12:21 PM
WFO's Avatar
WFO
Default Dash Dimmer Switch.
The dimmer switch on my '07 H3 doesn't seem to work. If I rotate the dial up or down, the dash lights do not seem to change. Is this normal??
Old Feb 4, 2008 | 12:32 PM
IHNEVELS's Avatar
Default RE: Dash Dimmer Switch.
They do change but not very much. i believe there has been talk about this in another thread. you can do a search for dimmer issues and should find it.
Old Feb 4, 2008 | 01:25 PM
WFO's Avatar
WFO
IHNEVELS.........Thanks for the search suggestion. I did do a search, but only came up with one thread that did not have many responses or a resolution. As such, I concluded thatmy dimmer switch issue is not wide spread.
Old Feb 4, 2008 | 04:35 PM
Trey124's Avatar
I just went out to my H3 and the lights don't dim that much. I don't know if that helps any, but the switch seems to work just fine.
Old Feb 5, 2008 | 07:23 PM
RealJeep's Avatar
Some things you just never know. I ran my 07 H3 through the full range with the lights on "on" "auto" and "park" and the result was the same each time. They were anywhere from bright to semi-dim but never almost off as most vehicles have the option of.
Old Feb 5, 2008 | 07:36 PM
mh307's Avatar
I do believe i started the thread about the dash lights, they really don't dim much, just a hummer thing i believe? Just figured i'd straggle in and throw my unneeded opinion in there.
Old Feb 5, 2008 | 08:03 PM
WFO's Avatar
WFO
Okay, so the dash lights don't really dim. I can live with that.[8D]
happythree
Sep 16, 2013 08:24 AM
frankieboy
Mar 4, 2013 12:41 PM
mrvictory1999
Oct 26, 2011 04:56 PM
myfirstH3
Mar 17, 2010 07:09 PM
peliti27
Aug 2, 2007 03:14 PM
