Dash Dimmer Switch.
The dimmer switch on my '07 H3 doesn't seem to work. If I rotate the dial up or down, the dash lights do not seem to change. Is this normal??
RE: Dash Dimmer Switch.
They do change but not very much. i believe there has been talk about this in another thread. you can do a search for dimmer issues and should find it.
IHNEVELS.........Thanks for the search suggestion. I did do a search, but only came up with one thread that did not have many responses or a resolution. As such, I concluded thatmy dimmer switch issue is not wide spread.
I just went out to my H3 and the lights don't dim that much. I don't know if that helps any, but the switch seems to work just fine.
Some things you just never know. I ran my 07 H3 through the full range with the lights on "on" "auto" and "park" and the result was the same each time. They were anywhere from bright to semi-dim but never almost off as most vehicles have the option of.
I do believe i started the thread about the dash lights, they really don't dim much, just a hummer thing i believe? Just figured i'd straggle in and throw my unneeded opinion in there. :):)
Okay, so the dash lights don't really dim. I can live with that.[8D]
