CTIS lower air alarm - disconnect
Old May 21, 2012 | 10:44 PM
Kzettlemoyer's Avatar
Default CTIS lower air alarm - disconnect
Can the CTIS alarm be disabled by pulling a fuse? CTIS is working fine, but I believe the sensor has gone bad because I am getting the low pressure alarm despite good tire pressure.
- Kurt
2003 H1
Old May 23, 2012 | 06:17 PM
joenuzz's Avatar
Hummer Fuse Chart for Trucks up to 2003
here is a fude box layout. I think fuse "1G" is the one that will get rid of the chime. Not sure though. It may also take out your CTIS. again, not positive.
Old Sep 22, 2012 | 10:32 PM
Ninjakawasakizx7rr@gmail.com's Avatar
Default Ctis alarm
Yes it's possible,we use to have to disable it for customers that would not be able to afford the repairs.
Old Nov 22, 2012 | 07:45 PM
cesar23w's Avatar
That alarm was driving me crazy. I have a problem with my CTIS pump and the rear tires kept going flat. I disconnected the CTIS at each tire this caused the low tire pressure alarm to go off. I located the alarm on my 2000 H1 right above the break pedal. All I had to do was to disconnect it and no more beeping.
Old Jan 15, 2013 | 09:29 PM
OkieH1's Avatar
Hello,
This is probably a dumb question, but do you have to disconnect the CTIS before you can manually air up your tires?
Old Feb 8, 2013 | 01:04 PM
gilbertherman's Avatar
You can just disconnect the CTIS alarm buzzer which is located under the dash beneath the black plastic kick panel. To find the buzzer .... follow the noise.
With both tires of a wheel set (front or rear) connected via engaging their CTIS valves, the air will equalize between the set. Think of the air pressure in the tires being connected by a rigid hollow tube. So, when you add air to one tire using the air chuck on that CTIS valve, you are really filling both tires.
Gil
juicebox123
May 19, 2015 02:51 PM
amra
Jan 10, 2015 07:37 PM
drag791
Apr 21, 2011 06:40 PM
justin67
Dec 18, 2010 01:12 PM
Offroad Escape
Jun 18, 2010 12:15 AM
