CTIS Issue using auxiliary hose
Old Aug 29, 2010 | 12:40 PM
gcompton's Avatar
Default CTIS Issue using auxiliary hose
I need to use a quick connect on my compressor to power an air diaphram pump for moving biodiesel and I'm having some issues.
1) Disconnect all tires
2) Connect my hose to the quick connect (added by previous owner)
3) Engaged CTIS Inflate (Front or Back or Both)
4) VERY low pressure through my hose
Next I
1) Connected all tires
4) I get great pressure through my hose and run the pump fine
5) I just have to watch the tires and then deflate and inflate to get my pump finished.
Next I
1) Disconnect front tires
3) Engaged CTIS Inflate (Front)
Same as above attempted but only with back tires disconnected and same result.
Here is a picture of my connect.
http://www.virxtual.com/Hummer/CTIS.jpg
Thanks for any thoughts.
Old Sep 7, 2010 | 08:58 PM
gcompton's Avatar
I worked with Scot from sax-express today to see if anything was actually wrong with my CTIS. After testing everything seems to be working fine.
I was just expecting more pressure from the aux line but it just doesn't have the power. It would still air up a tire or float but maybe in an hour.
I guess I will not use it for my pump.
Old Sep 9, 2010 | 03:02 PM
BigKofJustice's Avatar
The air pump on our CTIS system is a Thomas 100% duty cycle air pump. It can run continuously but has very low CFM, I believe it's around 1 CFM.
In order to run air tools, you'll need a compressor with up to 3-4 CFM ideally, with a reserve tank of air, otherwise you just run out of air.
What's happening in your case, when you have the axles connected and you hook up the Aux air hose, the air in your tires acts as a low pressure air tank, so all that air will get shunted from your tires out the air chuck to whatever tool or line you have hooked up.
A neat trick you can do with this, say you have to deflate a tire to change a CTIS valve.
What you can do is disconnect the wheel you need to work on, then inflate the one remaining wheel on that axle to 45 or 50 psi. Now disconnect that wheel.
Support the truck with a jack stand and delate the air out of the wheel you need to work on. Once you are done you'll have a tire with no air, and one tire with 45-50psi.
Reconnect both tires to the system and within a few seconds the air will equal out and you will have both tires at around 20-25 psi, then you can drive around and run the CTIS system to bring the tires up to whatever setting you prefer.
It's pretty cool to see the tire just inflate up in a few seconds doing this .
Old Sep 10, 2010 | 09:26 AM
gcompton's Avatar
That's what I have been doing now that I have found this out. Treat the tires as the tank, they can power my pump with no problems. I just have to pump tires up before I use it.
Thanks for the info!
Humdinger2
18
Apr 23, 2018 08:40 PM
mtrmble
Oct 19, 2008 07:30 AM
meyergsr
Nov 26, 2007 01:15 PM
my2002h1
Nov 24, 2007 11:48 PM
neilg
Oct 5, 2006 07:18 PM
