CTIS Failure
Old May 10, 2009 | 11:02 PM
paulmar's Avatar
Default CTIS Failure
My H1 CTIS failed in the worst possible place. Tires deflated to 15 psi on Washington coast beach. When it was time to go back, compressor kept pumping but at the same time deflating of tires was taking place.
SO here's what's going on. With engine running I selected front tires and pressed compressor switch to inflate. I can hear the compressor operating but at the same time the air escapes. Switching to deflate and than back to inflate doesn't make any difference. Switching to all wheels or rear only has no effect. Can someone help me.
Thanks,
Paul
Old May 11, 2009 | 10:31 AM
ronb's Avatar
maybe got sand in one your valves and it's stuck open? Happened to me once and I gave the manifold/solenoids some good tapping with a large maglight to knock the debris loose. I'm assuming you got out of there ok by disconnecting the tires from the system and filling them manually?
ron
Old May 11, 2009 | 02:51 PM
hummech's Avatar
i would pull the valves apart and clean the sand out of them. sand gets into the system and when you deflate the tires sand gets caught in the deflate valve and it won't close or seal itself closed. when you pump ibn the air with the deflate valve open, the ctis pump will pump air but it goes out the deflate valve into the atmisphier and not to the tires.
Old Jun 19, 2009 | 04:20 PM
AT6Stick's Avatar
check the pressure relief valve on the valve manifold spring is probibly weak or has sand in it
Old Jun 20, 2009 | 08:14 AM
paulmar's Avatar
Thanks,
It is up and running now.
Paul
brachilius
28
Feb 3, 2011 08:04 AM
paulmar
May 11, 2009 09:08 AM
hudson4269
May 15, 2007 10:04 AM
KTMCanuck
Sep 5, 2006 06:38 PM
