Crazy Electric is working backwords (Mirrors, Window Washers, Drivers Window)
Old Feb 7, 2016 | 04:40 PM
ynot44444's Avatar
Default Crazy Electric is working backwords (Mirrors, Window Washers, Drivers Window)
Just purchased a 2008 H3 and it seems that the previous owner might have messed with it or it's just freaking out.
1. Drivers side rear view mirror is moving the opposite direction than it should. When I go to push the button to raise it, it lowers. When I push the button to lower it, the mirror raises. ???
2. I replaced the door switches for the windows because the driver window would not work all of the time. It works when it wants to work but when it's not if I pop open the switches and unplug the panel and plug it back in it starts to work again (sometimes). Sometimes I have to completely turn the ignition off and back on before it will work. ???
3. The window washer controls work for the opposite windows they are suppose to work for. When I hit the rear window washer fluid button, it sprays the front window. When I turn the front window washer fluid control, it sprays the rear window. This is obviously electric but I have no idea where to begin. ???
Thanks in advance for your suggestions!
Old Feb 7, 2016 | 10:04 PM
rsc's Avatar
rsc
I read a post from a guy with an 06/07 that had swapped his door panels and controls out for the later style door panel and controls and his controls were all off like that. I don't think that's your problem, but thought that was interesting.
Old Feb 7, 2016 | 10:32 PM
ynot44444's Avatar
I have been chasing wires all day and can't seem to find the problems.
Old Feb 8, 2016 | 06:21 AM
Does it have a sunroof? Is your BCM behind the passenger kick panel wet?
Old Feb 8, 2016 | 11:55 AM
ynot44444's Avatar
No Sunroof, but I will check the kick
panel. Thank you
Old Feb 9, 2016 | 06:38 PM
ynot44444's Avatar
BCM was dry and clean.
Old Feb 9, 2016 | 09:26 PM
RKSmith163's Avatar
You have 2 pumps for the windshield washers. Someone has switched the hoses.
Old Feb 10, 2016 | 08:08 AM
ynot44444's Avatar
Never thought about that RKSmith. I will check that today!
Thanks!
JensH2
Sep 14, 2025 08:52 AM
Astro5169
Apr 12, 2014 08:08 AM
minta7
Jan 14, 2013 09:32 AM
Gooch
Dec 7, 2007 01:15 PM
egombrich
Jan 12, 2006 04:53 PM
