Courtesy light problem
Old Aug 23, 2011 | 01:09 AM
edbuzz's Avatar
Default Courtesy light problem
Ok, I really could use some help here, I have a 2006 h2 and I was changing the rear seat courtesy dome light and forgot to shut the door(I know, stupid mistake!!) so it had power going to it and when I went to snap the new bulb in, it sparked and went out. Now all the courtesy lights are out except the front door lights. The map lights still turn on when you press the buttons.
I thought it would just be a fuse but I cant find one that is bad and the owners manual doesn't even show one for this. I went through the fuses one by one , no luck.
Any ideas??????
Old Aug 26, 2011 | 12:39 PM
LIL-TNK's Avatar
Technically it sounds like a blown fuse or a tripped circuit breaker.
Have you tried checking if the "non-functional" bulbs work with an outside power supply.
or
You could just take it to a car-shop... ofcourse minimum fee will be around $50.
Old Aug 26, 2011 | 12:59 PM
edbuzz's Avatar
or
Yes, I checked the bulbs they are working. There is no specific fuse for these lights listed in the owners manual so I pulled each fuse and checked them and they all look good.
I might have to take it to the shop.
Old Aug 26, 2011 | 06:08 PM
drtom's Avatar
Banned
swap identical relays around ,see if any changes, disconnect batt,short leads
Old Aug 27, 2011 | 12:57 AM
edbuzz's Avatar
Didn't think about swaping relays, I'll have to give that a try.
I tried disconnecting battery, that didn't work.
What do you mean by short leads?
Thanks For any ideas you have!!!!
I'm stumped right now
Old Aug 27, 2011 | 07:42 AM
drtom's Avatar
Banned
oh, touch batt leads together,some said that completly resets system,,,??
flrtrader
Nov 29, 2017 01:19 PM
liveinxs
Mar 25, 2015 05:30 PM
clinecs
Feb 10, 2008 08:19 PM
finall
Nov 27, 2007 05:01 AM
