Coolant smell when turning on heater ?
Old May 2, 2011 | 10:43 PM
If it is leaking outside the cab by the coolant tank it could be a bad coolant tank cap, a crack in the coolant tank or possibly a loose clamp. If it is leaking inside the cab it is most likely a bad heater core. Check out Flash Off-Road Hummer Accessories, Hummer Maintenance, Modifications and Tech info and read the repair article on heater cores.
Old May 3, 2011 | 07:05 AM
jordan572's Avatar
wouldn't the heater core be the only reason for the very bad smell of antifreeze when the heat is on?
Old May 3, 2011 | 06:33 PM
Could be a loose clamp on the lines leading into the heater core but usually it is the heater core.
Old May 8, 2011 | 04:16 PM
hummech's Avatar
a cracked heater core could also drain only out side the vehicles. it leaks the fluid out where the condensation leaks from the a/c drain hose. you would still smell it inside the car but it would leak out side from under the coolant surge tank.
IronmanH3
Mar 9, 2012 06:42 PM
inked
49
Feb 3, 2009 08:08 PM
fastboatnut
Jan 11, 2009 07:27 AM
SafariHummerH2
Nov 28, 2008 09:07 AM
GregDiesel
Jan 6, 2006 03:24 PM
