CLUSTER LIGHT REPLACEMENT
Old Jan 14, 2009 | 04:41 PM
SafariHummerH2's Avatar
Default CLUSTER LIGHT REPLACEMENT
Hello friends,
I noticed that I have some cluster lights blown.
I know that there a two types of cluster lights in the H2 depending on the manufacturer date.
Some clusters were made with regular removable incandescent lights and others with L.E.D.'s.
My H2 has the L.E.D. type.
The service book says if you have the L.E.D. type, I would have to take the cluster in for servicing.
I removed the cluster from the vehicle to try to service it myself with some L.E.D.'s I'll purchase from "RADIO SHACK".
But I need to separate the cluster form the plastic mounting base to get to the blown L.E.D.'s
I removed the cluster mounting screws to the mounting base but I can't back out the cluster from it's plastic mounting base because the indicator needles from the speedometer and odometer, etc. are attached and won't let the cluster separate from the base.
I don't want to force anything out since something might break or snap off.
Does anyone know how to separate the cluster from the plastic mounting base without breaking anything?
How do I remove the indicator needles or how can I bypass them?
Is there a special set-up or procedure to separate this type of L.E.D. cluster from the mounting base?
Safari Hummer H2
Old Jan 15, 2009 | 03:08 PM
HumminNBoatin's Avatar
Default RE: CLUSTER LIGHT REPLACEMENT
Sounds to me like they are not serviceable. And really LED lights should almost outlast the life of the truck.
Caraddict
Oct 9, 2013 04:59 PM
KBueno
Jan 17, 2011 12:16 PM
Sooner1
Nov 22, 2010 09:59 PM
Sooner1
Sep 26, 2010 09:55 AM
Trailnuts
Aug 27, 2010 10:16 PM
