Climate control fan making ticking noise
Old Aug 29, 2007 | 09:49 PM
HammerDown's Avatar
Default Climate control fan making ticking noise
This is on an '03 H2 the blower motor fan is making a ticking soundlike therelike the fan blades are hitting thr housing. This happens intermittantly while driving. I took the passenger side kick panel off and if I push on the bottom of the blower motor I can make it stop and start making the noise but there doesn't seem to be any rhyme or reason to it. Has anyone else had this problem? I really hope the blower motor isn't going out because I am sure it is $$$ and a pain to install.
Old Aug 30, 2007 | 04:35 AM
blackstangs281's Avatar
Default RE: Climate control fan making ticking noise
How bad is it? Does it sound like a leaf or something might be stuck in there?
Old Aug 30, 2007 | 11:03 AM
HammerDown's Avatar
It does sound like a leaf is stuck in there. I wonder if there is any way to gain access to the inside without pulling the dash apart.
Old Aug 30, 2007 | 12:20 PM
RealJeep's Avatar
Stick a shop vac or leaf blower in the re-circ panel under the pass. side dash and blow. Make sure the A/C control is set to re-cir or the Max setting. Ford's used to be BAD about that.
Old Aug 30, 2007 | 01:43 PM
HammerDown's Avatar
Well it turns out the blower motor is very easy to remove. Pull off the passenger side kick panel and then remove three screws and the blower motor drops out the bottom. Sure enough I had a big *** pine needle in there!
Old Aug 30, 2007 | 04:54 PM
Glad you had an easy cheap fix
vroomazoom
Jan 26, 2012 12:39 AM
Flashawd
Jan 15, 2012 09:34 PM
Songman
Dec 11, 2011 07:31 AM
mdavis
Jul 15, 2010 03:10 PM
THE BEAST
16
Oct 23, 2009 03:30 AM
