Climate Control Bulbs change
Old Dec 29, 2012 | 01:07 AM
RaYoSeKiZ's Avatar
Default Climate Control Bulbs change
Any idea on how to change these bulbs??
Please help!
Old Dec 29, 2012 | 10:38 AM
DAGKANA's Avatar
It's a sealed unit that typically GM says you have to replace the entire unit... However there are bulbs in there that can be replaced w/ LEDs = problem solved... Ill have to search out which ones...
Old Dec 29, 2012 | 12:06 PM
fireman_343's Avatar
Was just wondering the same thing... My temp control **** light is out.
Old Dec 29, 2012 | 12:21 PM
RaYoSeKiZ's Avatar
The one in the middle is busted. I ordered replacements and received three so I might as well change the 3.
But I need your help how to do it.....
Thanks in advance
Old Dec 29, 2012 | 05:21 PM
Back9's Avatar
With a small screwdriver pry back on the face plate that surrounds the radio and temp controls at the very top, once you have it started then pry back down the sides and it will pop out.Then disconnect all the wire connections, you may also want to move the gearshift down out of the way. With the face plate now in hand pry the tabs away carefully on the back of the heater control ***** while pulling the box out at the same time, you may want to use a couple of credit cards to keep the tabs from snapping back into place. Once in, the three bulbs just twist out. This whole proceedure should only take 15 minutes. The only place to find the bulbs was on Ebay the dealer will not have these. The window switch bulbs are also the same. Heres the link for the bulbs.
(8) MINI WEDGE BULBS 2005-2010 HUMMER H3 HEATER/A.C CONTROLS & WINDOW SWITCHES
Old Dec 30, 2012 | 12:28 AM
RaYoSeKiZ's Avatar
Thanks a lot to all the response especiALLY THE lastone very helpful
Old Jan 2, 2013 | 02:40 AM
smpfalzer's Avatar
This thread was already made. It will give you some good visuals for the task.
https://www.hummerforums.com/forum/h...removal-16478/
Old Jan 3, 2013 | 07:50 AM
telemike's Avatar
I bought bulbs off ebay that were direct fit replacements. Spent more time taking apart the module.
Old Jan 12, 2013 | 11:34 AM
Back9's Avatar
the module should not take more than a couple of minutes as long as you keep the taps from snapping back into place for those of you reluctant to attemp this proceedure
w3sCiH3
H3 Frequently Asked Questions
Oct 12, 2020 10:18 AM
drgray7
May 19, 2010 10:55 PM
matelblapav1
Feb 1, 2009 06:37 AM
HammerDown
Aug 30, 2007 04:54 PM
crc2k
Jul 14, 2006 11:54 PM
