changing the water pump
Old Jan 6, 2014 | 11:58 AM
loud pipes's Avatar
Default changing the water pump
Has anyone changed the water pump in a 2006 H3 3.5L? I searched this thread and didn't have any luck, unless I used the wrong search terms (sorry if this is redundant). I have 130k miles on my H3 and just started hearing what might be a bearing grind sound from behind the fan. I am looking for any helpful hints or pitfalls before jumping in.
Thanks!
Old Jan 6, 2014 | 12:30 PM
happythree's Avatar
I never have luck searching but I do find everything in the h3 svc manual. you can download cheap here or elsewhere.
oh, be sure its the pump huh.
Old Jan 6, 2014 | 01:01 PM
Super easy, hardest part is getting the shroud out of the way.
See this thread, you may have to join CHO to see it if the link does not work for you. Water Pump Replacement
Old Jan 6, 2014 | 03:08 PM
loud pipes's Avatar
Great. Thanks for the help!
Old Jan 6, 2014 | 05:45 PM
lex's Avatar
lex
overall its not bad, getting the damn fan off is the worst. I broke the bolts holding water pump on the first time so use a torque wrench
Old Jan 9, 2014 | 07:39 PM
Reineke's Avatar
I think the spec on the water pump bolts is around 89 IN lbs (not foot) around 7.5 foot lbs. Best to use a 1/4" drive if you don't have the torque wrench. Easy to break off.
Old Jan 11, 2014 | 01:02 PM
kurteken's Avatar
Thanks!
Look at this. Is the same for us H3 drivers
Regards
Kurt
Old Jan 11, 2014 | 09:04 PM
stvnkrchnr's Avatar
The pump is easy, the Tstat is a hard bitch to get to. I just did pump, fan clutch, Tstat, upper and lower hoses, belt, tensiner and idler.
All that took maybe 5 hours and the fan shroud is kinda tricky lol. It took a minute to figure when to wiggle and when to pull up but I've got it figured out now and its easy.
Old Jan 12, 2014 | 07:30 AM
loud pipes's Avatar
That's a big help. Thx for all of the responses!
helicfii
Jun 6, 2022 11:16 AM
dizzy
23
Feb 21, 2011 09:15 PM
qakhan
Jun 10, 2008 03:13 PM
jstdoitt21
17
Jan 31, 2008 02:25 PM
Dennis C
Sep 5, 2007 07:35 AM
