Cel-p0171
Old Oct 29, 2012 | 05:43 PM
07rollinh3's Avatar
Default Cel-p0171
Hello Everyone-
I am new to the forum, but thought this information may be helpful. I recently started experiencing intermittent CEL. HP tuners revealed a P0171 (lean bank 1). I changed my upstream 02 sensor, and the light remained. I had taken off my throttle body once before to clean it, so I decided I would disassemble that whole upper assembly that sits on top of the manifold. Sure enough, I found a cracked hose (figured it could be a vacuum leak). The hose is underneath the back of the big plastic piece that site between the TB and the air filter box.
Here are some pictures:
Taking it off was pretty easy. two bolts hold the plastic piece to the manifold (10mm, like most bolts under the hood)
Then Loosened the Hose clamps (four, flathead screwdriver)
The cracked hose that connects from the large plastic piece to the manifold
The New Hose ( I chose to use hose clamps):
The CEL is now gone! Hope this helps.
Old Oct 30, 2012 | 02:30 PM
The "big plastic piece" is known as the resonator box. The hose under the back to the breather port at the rear of the left valve cover is the secondary PVC hose.
Thanks for the thread, might give people a place to look for their leak when they get a P0171.
Old Oct 31, 2012 | 12:17 PM
Smittro's Avatar
Thanks for the write up.. Oh, is that a WS6 T/A I spy there?
Nice choice in toys! Former owner of a 01 Camaro myself..XD
Old Oct 31, 2012 | 10:50 PM
07rollinh3's Avatar
Thanks guys. Yes, it was a 2000 ws6. It's now a shell. Most recently an iron 346 and a pt8847 came out of it. Bigger motor is going in, same turbo though.
Old Mar 25, 2013 | 01:38 PM
07rollinh3's Avatar
UPDATE:
Still no CEL light months later. Replacing that little hose has fixed the issue.
Old Mar 25, 2013 | 09:59 PM
Happy Hummer's Avatar
Good to know.
Actual part# 15123628
Chris
Mighty455
27
Jun 27, 2015 08:50 AM
jerferg
Oct 28, 2013 03:23 PM
user 956363738
Jan 19, 2012 10:14 AM
06h3lux
Jan 7, 2012 10:07 PM
ken haukaas
Jan 11, 2011 08:14 PM
