Can I get bluetooth in 2007 H3 with oem navigation?
Old Apr 6, 2009 | 12:15 AM
magicacaca's Avatar
Default Can I get bluetooth in 2007 H3 with oem navigation?
Been looking at the Parrot MKi9000 bluetooth car kit (OnStar doesn't work in my country) but I have the oem navigation unit installed. Parrot states that the kit won't work with the oem unit which has a separate amplifier.
Question is, does the oem nav unit have a separate amp.
If so, can anyone recommend a solution for bluetooth/ipod for 2007 H3?
Thanks!
Old Apr 7, 2009 | 05:46 PM
gregaac's Avatar
If you have the OEM navigation, then there is a separate amplifier in the car. The standard radio with CD has the amplifier built into the radio, this is why you can't swop out to the Navigation if you don't have the wiring and amp in the car. I'm guessing that parrot states it won't work because you are bypassing the amplifier which is needed to hear through your speakers when the bluetooth is on.
I had a similar problem when I tried to install aftermarket modules. Onstar offers a package which works with your cellphone through the car's system. I know you stated in your country you don't have Onstar, but maybe your dealer can hook something up with your cell phone through the existing antenna used by onstar. Just a thought. Other than that, I can't think of any other option but to purchase an external bluetooth unit like Motorola or change out your entire radio.
Old Apr 18, 2009 | 06:47 AM
Carcrazy's Avatar
Banned
i have the solution
Old May 4, 2009 | 10:29 AM
ungarocd's Avatar
The Parrot kit does work with the amplified system, but you have to use a couple relays to do it. Basically you use the output of the Parrot kit to trip the relays and make them cut off power to the amp temporarily. As soon as the call is over the relays flip back and the amp comes back on. It's a tricky setup, but I've done it many times.
Old Aug 4, 2009 | 02:52 PM
H3Tsinda's Avatar
Originally Posted by Carcrazy
i have the solution
What would be the solution? I have the 6 Disc Monsoon radio on my 09 H3T, is there a way to install bluetooth as well as an IPod interface? Onstar doesn't work in Mexico either...
Thanks.
Old Sep 2, 2009 | 02:23 PM
Smart Nu's Avatar
I have a similar question I have a 2008 Hummer h2 it came with the upgraded stereo DVD/CD (no navigation) can I set up a bluetooth I-phone? if not how can I make it work?
Old Sep 4, 2009 | 05:47 PM
AriesH3's Avatar
My H3 just has the regular non navigation radio in it. I have been looking to upgrade to the touchscreen navigation. What would you all recommend?
Thanks.
SundownAudioNY
Sep 6, 2011 03:02 PM
bnobel
Dec 11, 2010 08:01 PM
Alfieg23
Oct 24, 2009 04:04 PM
jeep60s
Oct 16, 2009 04:55 PM
davyo
Oct 26, 2006 02:16 PM
