Broken bolts on manifold for catalytic converter
Old May 18, 2016 | 03:21 PM
Carbon24K's Avatar
Default Broken bolts on manifold for catalytic converter
The dealer told me I needed a new catalytic converter. Now at installation he tells me two bolts are broken requiring the removal of the manifold.
I was told it is a 12 hour job at a cost of $1900 bucks. That does not include the install of the new catalytic converter at an additional $1800. total $3700
I need a little help . . . are they off the wall or is this pretty close to the right cost.
Thank you
Old May 18, 2016 | 07:24 PM
Happy Hummer's Avatar
Haha... run do not walk.
The cat/manifold can be gotten for between 350 & 700 approximately the bolts can be extracted by a competent shop with proper tools. At say 85 per hour for a few hours to remove the broken studs and the installation of a manifold cat you should be in the 2k range or less.
Old May 19, 2016 | 01:16 AM
Bunger's Avatar
A dealer is the LAST place I would take my vehicle.
Go to a good independent mechanic for a reasonable cost.
Old May 19, 2016 | 09:58 AM
Thank you
What two bolts? Are we talking about bolts at the collector of the exhaust manifold/Cat pipe flange, or bolts to the head for the exhaust manifold? Any monkey can fix broken bolts at the collector without removing the manifold???? They use this thing called a drill.
Did they break the bolts while attempting the replacement???
There are two Cats for an I5 H3, one mini in the Exhaust Manifold, and a full Cat in the mid pipe behind the manifold. If they are replacing the rear Cat, no reason to mess with the Manifold.
badss98
Jun 22, 2021 09:50 AM
madmayo
Jun 23, 2014 12:37 AM
kseaman
Jan 24, 2013 07:52 PM
Bronx
Apr 16, 2008 05:49 AM
hummer_04
Jul 12, 2007 12:21 AM
