Brake Pad Part Number?
Old Dec 18, 2007 | 02:56 PM
mountainbiker's Avatar
Default Brake Pad Part Number?
Gang,
I am looking to get some front and rear brake pads. Does anyone have the GM p/n for the front and rear sets for the 2006? I couldn't seem to find any web sites with clear and consistent info for the H3 brakes. For example,
https://www.hummer-parts.com/oe_parts_catalog.html -
Accelerometer, hummer h3, without active brake 2006 $83.20 $0.00 $59.28
brakes - Anti-lock brakes - Accelerometer
Accelerometer, hummer h3, with active brake 06-07 $271.04 $0.00 $193.11
What the heck is active brake? Isn't $193 a bit steep for a set of pads?
http://www.gmpartsdirect.com/catalog/frameset.cfm -
Front pads, hummer h3 06-07 $165.65 $165.65
Rear pads, hummer h3 06-07 $152.54 $152.54
Any guidance / assistance with the H3 brakes would be appreciated.
Old Dec 18, 2007 | 04:10 PM
Default RE: Brake Pad Part Number?
Raybestos Quiet Stop Ceramic OE replacement Lifetime warranty....atAdvance Auto
Front: PGD1119QS $65.99
Rear:PGD1120QS$83.99
Active brake is part of the StabiliTrack system on the H3 w/ auto trans. Here is an old article so you get the idea http://media.gm.com/ca/gm/en/vehicle...ancem_en.htmIf
If I remember right ?? ?? the Manual Trans did not come with StabiliTrack in 06?
Old Dec 18, 2007 | 04:49 PM
Thanks Doc for the link http://media.gm.com/ca/gm/en/vehicle...nhancem_en.htm and aftermarket part numbers.
My 2006 auto has StabiliTrak whereas my coworkers 2006 manual does not. (Of course, we both have Traction Control.) So, are the pads different between those with StabiliTrak and those without StabiliTrak? If so, we have two different part numbers like the Hummer-Parts.com is seeming to indicate. Is StabiliTrak on the front wheels or all?
To confuse things, GM Parts Direct and the Advance Auto Parts numbers are only listing a single set of numbers per axle (with no reference to active braking). GM Parts Direct is showing the front set as more expensive, and Advance Auto Parts is showing the rear set more expensive. If the pads were nearly identical between front and rear, you'd expect the price to be nearly identical. If StabiliTrak was only on one axle, then you'd expect the price to be higher for that set.
If you look at the HUMMER H3 Service Manual (p. 5-68 and 5-69), front and rear are definitely different. The front appear larger (than the rear) with retaining pins, shims, and clips. Bigger and more pieces -- you'd think the front should be more expensive.
Ahhhhhhh.........
Any one know if GM embosses the part number on the brake pad assembly?
Old Dec 18, 2007 | 08:53 PM
The active brake system is all four corners, with StabiliTrack equipped H3s. Guess my memory is not as rusty as I thought?
I would NEVER buy brake pads thru GM dealers, that's just a hose job in the wallet. Go with good quality OEM replacement type pads from your favoriteauto parts. In your case I guess you would be alright over the net and have them shipped to you? All the after market parts I checked do not distinguish between the 06/07 with or w/o the stabiliTrack, so I'm guessing that is GM being **** on the part number assignments?
foothillboy
May 20, 2010 07:54 PM
Ken06H3
Nov 2, 2009 05:02 PM
NJTEX
Jul 6, 2009 12:50 PM
lucky19942001
Jan 28, 2009 05:07 PM
brachilius
Mar 19, 2008 03:24 PM
