Body Allignment
Old Jan 29, 2006 | 04:36 AM
Raffi76's Avatar
Default RE: Body Allignment
What does you H3 idle at guys ? 1000rpms as Dilo said is I think more then mine.... If I am not mistake mine idles just above the first line, so aboce 500rpms..... if you get a chance Dilo can you take a look at yours?? when its cold it might be a bit higher, but if I drive for a while, its right about there
Old Jan 29, 2006 | 03:10 PM
dilo2001gt's Avatar
Raffi I check out mine when you first start it it goes to 1000 rpms i put it in drive still 1000 rpms then once it warm up it went to 500 rps like you said.
I konw my 4 runners always stayed at 1000rpm diff motor but you never knew they where running at a stop these H3 are rough ideling which i have to get use to
Old Jan 29, 2006 | 03:36 PM
Dennis's Avatar
Mine revs on start up to about 1200 RPM (Hot) and then idles down to about 600 RPM (Hot)...Course I have a Cold air intake and Free flowing exhaust, I don't know if that makes a difference[sm=nerd.gif]
Old Jan 29, 2006 | 04:00 PM
Raffi76's Avatar
So the way it idles seem to right.... now the question is what is with the rpm drop, honestly I can't even tell what it is exactly as when I look at the rpms its usually too late as it happens very fast. It seems like a vibration going through the engine and car as though AC was comming on, but it happens when AC is on and off, this it can't be the AC...... I wonder if anyone else experienced this
Old Jan 29, 2006 | 08:25 PM
Dennis's Avatar
ORIGINAL: Raffi76
I know what you're trying to explain...I think it maybe an issue with the mass airflow sensor (MAF)..I've seen this before...It's a small part on your intake..An Easy fix too....But whatever it is, it aint normal for the spuratic idling..Take it in soon.
Old Jan 29, 2006 | 10:31 PM
Raffi76's Avatar
Thanks Dennis !! I also noticed today this happens when I back up while parking, it almost seemed like it is going to die on me..... this is only the second time it happened on backup so I forgot all about it..... I will definitely mention this to my daler, my car is going in for some major work any day now,,,,, I have so many things wrong with it you would not believe.... last time i took it in to replace a sunroof they made such a mess in my car that I was going to shot each of the mechanics.
chrisstaton
Dec 27, 2010 07:08 PM
madmike
Jan 26, 2009 07:36 AM
cigarlvr
Dec 21, 2007 07:19 PM
westsydetrucknrod
Jan 7, 2006 08:53 PM
shortbus
Nov 10, 2005 05:34 PM
