Bilstein shocks & Bilstein Steering Stabeliser Replacement, WOW!!
Old Dec 22, 2012 | 11:31 PM
  #21
PatentGuy's Avatar
Default Me too
I also had my shocks replaced about 6 months ago with the Bilsteins - the ride is equally smooth to OEM (before the OEM became worn), but they are a bit firmer in transitions - so more "European". Thus, the truck leans a little less and is a bit firmer over bumps. Or this is my opinion.
Seems like I need to replace that steering damper....
Old Dec 23, 2012 | 05:44 PM
  #22
redlx50's Avatar
I just installed the bilsteins today. took about 2 hours to do the fronts and rears. I found the wire bundle that runs on the top of the frame on the drivers side was getting damaged from the heat from the exhaust manifold. I was wondering if anybody else had experienced this? I taped up the wire loom with electrical tape and secured it away from the manifold by zip tying it to the brake hard lines on the frame.
Old Dec 24, 2012 | 12:24 PM
  #23
Man1nboat's Avatar
UPDATE: Bilstein's installed... They said the rear shocks "shouldn't have on the vehicle and were totally shot", the front's were "leaking for some time", and the steering damper was not leaking but due to be changed. My H2 has 80K miles and rides fantastic now! Smooth yet firm ride, no rolling or nose dive during braking, and a 2-3 MPG increase (just seeing if you were awake!). They also went on sale for ~$80 (X5) each so out the door installed was ~$590.
Old Dec 25, 2012 | 08:05 AM
  #24
Pacopatron's Avatar
Nice!! I like mine also..
Old Jan 26, 2013 | 08:34 AM
  #25
H2Miami's Avatar
I was looking online info for the shocks replacement and everywhere shows the Bilstein Heavy Duty (HD) Shocks
BE5-A936-H0 (FRONT RIGHT&LEFT)
BE5-A937-H0 (REAR RIGHT&LEFT)
as the recommended ..... Any reason to go with the 5100 series ... Price is the same for both
No lifted truck ... No used for offroad
Thanks for the inputs
Old Jan 26, 2013 | 09:17 AM
  #26
Man1nboat's Avatar
Previous information: "I am having the Bilstein's installed Monday morning (5100 BIL 24-186735 front, 4600 BIL 24-185912 rear, and BIL 33-174525 dampener) for $615.88 installed."
From your information, the 936's are 5100 and 937's are 4600 shocks...
I bought mine from 4 Wheel Parts, have 2007, un-lifted with with rear coil springs:
Bilstein Shocks - Shock Absorbers - Shock Absorbers & Shock Accessories - Lift Kits, Suspensions & Shocks - by 4 Wheel Parts
My guess is that even though my H2 isn't "lifted" it is designed for off-road applications and geometry. Other sites I looked at also suggested the 5100/4600 combination...
Old Jan 26, 2013 | 10:31 AM
  #27
H2Miami's Avatar
Thanks ... "My guess is that even though my H2 isn't "lifted" it is designed for off-road applications and geometry. Other sites I looked at also suggested the 5100/4600 combination" ...Makes sense well after seen everyone getting that set up , I guess Im going to have the same ... Going have installed on Monday . I will post
Old Jan 26, 2013 | 12:08 PM
  #28
Man1nboat's Avatar
I believe you will really like them. Mind you, my rear shocks were shot as previously stated... but the ride's is very good with the Bilsteins. Good luck
Old Feb 12, 2013 | 10:58 AM
  #29
H2CANEPADESIGN's Avatar
Got My 5160 series bilsteins here today. Can't wait to install them!
Old Feb 12, 2013 | 04:59 PM
  #30
Man1nboat's Avatar
Front and rear? Those are awesome! $$$ :-)
