Best way to remove head unit/nav unit?
Old Jul 20, 2011 | 04:36 PM
Broken Halo's Avatar
Originally Posted by drtom
minor point, i use 2 fingers on right hand,lift up and pull out.
orrrr.....you can make a little tool like this one. I bent a piece of coat hanger to have a small hook at one end, and a 'T' shape at the other for the handle. Inside the 12v receptacle on the passenger side, there's a rectangular cutout all the way in, at about the 5 o'clock position. Insert the tool hook into the cutout, give it a sharp tug, and the trim panel will pop free in that area. Then you just work around it by hand to free the rest of the clips. IMPORTANT!!: Use heat shrink tubing as an insulator to cover the straight part and hook, as, otherwise you will short the positive terminal inside to the outer section, and blow your fuse. I also wrapped electrical tape around the handle, and used some vinyl caps I had for the hook tip, and handle ends. This thing has come in handy more times then I can count, with all the times I've pulled the panel.
Attached Thumbnails Best way to remove head unit/nav unit?-dsc00684.jpg   Best way to remove head unit/nav unit?-dsc00685.jpg
Old Jul 21, 2011 | 12:08 PM
drtom's Avatar
Banned
Default grate idea,,
now im lookin at a plastic,,fiber,insulated gizmo,,,later
Dieseldrums
Jan 24, 2015 11:08 PM
drtom
Apr 21, 2012 02:49 PM
drtom
Apr 20, 2012 10:50 PM
Caraddict
Jun 19, 2011 04:04 PM
Size-Matters
Jan 1, 2011 11:30 PM
