Battery Issues!
Old Aug 22, 2015 | 06:23 PM
Hummerrookie's Avatar
Exclamation Battery Issues!
Hi Fellas,
I just picked up my military 1992 M998 Humvee from a military auction last week and I'm already having some issues.The car turned over and started ran up right away for the first few days. I only drove it about 10 miles around town. Day 5, the car won't start. I had the battery jumped by AAA and it was fine. In order to charge the batteries up I drove the car around for about 40 minutes. As soon as I shut the car off the car would not restart. The car had no indications of battery issues before all this started.
1) Do you believe the issue is the Batteries or the Alternator?
The car also had no weird sounds but just before I shut the car off it was making a loud squeak like a belt would make. The sound was only when accelerating. Any idea what the issue is?
Thanks for your help guys I really appreciate it.
Old Aug 23, 2015 | 04:54 PM
Take the battery out and have it tested. It could be bad and not be holding a charge. Alternator would be the next thing to check if the batteries are ok.
Squeal is likely a belt.
Old Aug 24, 2015 | 02:55 PM
V-tek's Avatar
can you check the tensionor on the belt and see if you have the correction tension? There is a mark that should be between to other marks to show if the tension is correct.
If you don't then it won't change as good as it should. If you run the motor and see that you are getting 14v then it shouldn't be the alt.
Old Aug 27, 2015 | 11:02 AM
V-tek's Avatar
Humvee... Forgot that is a 24v system...
bluebow
Feb 22, 2021 10:39 AM
FUBAR
23
Mar 10, 2011 11:12 AM
lucky19942001
Oct 20, 2010 03:46 PM
2007h3x
Nov 2, 2009 07:31 PM
bigjdhoss
24
Apr 6, 2008 12:32 AM
