Base Model Radio Tweeter Wiring
Old Feb 1, 2012 | 09:33 PM
jvorpahl's Avatar
Default Base Model Radio Tweeter Wiring
I'm getting ready to install aftermarket component speakers in the front of the H3. I have the base radio model. I wanted to use the stock wiring harness for both the tweeters and mid-base driver. According to the wiring diagrams the tweeters are wired in series with the mid-base driver. I thought this would work perfect b/c I could simply cut the line going to the tweeter and wire that into the crossover but if you pull the mid-base speaker out you see no wires leading to the tweeter. I know the radio only has a single wire so it must split somewhere between the radio and mid-driver. Does anyone know where it splits?
Also, is there a stock crossover of some sort built into the tweeter line and mid-driver line? It doesn't look like it on the wiring diagram but the tweeters sound like they just output the high frequencies and the mid-base driver seems to just output the mid and lows. I have an aftermarket head unit so I know it isn't the radio that is doing the eq'ing and there is only one output from the radio. How would they do this w/out a crossover?
Old Feb 1, 2012 | 10:15 PM
See your post on CHO! I left you an answer there.
Old Feb 2, 2012 | 10:49 AM
jvorpahl's Avatar
Thanks a bunch for responding. Just in case anyone else is wondering there is a small capacitor soldered onto the tweeter itself that acts as a crossover. Now all I need to figure out is where the wires split. If it's at a spot I can't get to I'll just have to run my own wires from the crossover to the tweeter. If anyone has had experience with running wires from the mid-base driver to the tweeter I would love to hear how the did it and any gotchas.
DarinM
Aug 8, 2010 03:02 AM
CarlosC
19
Dec 1, 2009 08:35 PM
wes07H3
May 21, 2009 09:47 PM
CarlosC
Oct 12, 2006 12:10 PM
khoolhandz
19
Aug 16, 2006 01:23 AM
