arcing noise in ignition
Old Apr 25, 2012 | 04:51 PM
kellyawright's Avatar
Default arcing noise in ignition
Can anyone suggest what to do about an arcing noise when I turn on the truck. It does not occur when I put my seatbelt on before turning on the truck...very strange. Dealership said it was just a hiccup and nothing could be done. I had an 2006 H3 with the same problem but they said the battery wasn't hooked up properly and they solved the problem. This does not seem to work with my current 2009 H3. Help please
Old Apr 25, 2012 | 09:20 PM
DevinAshlee Shorts's Avatar
there is a lock cylinder by the ignition that can be making the noise its controlled by the body control module.. you can try ordering the bcm from dealer hook it up (may need to be programmed) if it goes away buy it if not return it...
Old Apr 28, 2012 | 10:43 AM
drtom's Avatar
Banned
Default buy it if not return it... Reply With Quote
id like to be the first to know if you get away with this!!
Old May 1, 2012 | 10:48 AM
This has been moved to the H3 section, since that is what truck this question is about, so maybe somebody can answer it???
The Hummer Forums Help & Suggestion Center has nothing to do with technical vehicle questions, it is for questions or suggestions on how the forum software works.... like........... "how do I post a picture?" kinda stuff.
HERHMR
16
Dec 26, 2012 11:11 AM
hummerhonduras
42
Sep 19, 2012 11:49 AM
hulkh3
Sep 12, 2012 08:02 AM
racepet
Jun 10, 2006 05:40 AM
carissa
Apr 18, 2006 12:48 AM
