Any problems with front windshield?
Old Feb 10, 2007 | 07:37 AM
  #31
blackstangs281's Avatar
Default RE: Any problems with front windshield?
ORIGINAL: Dennis
Mikeymike..Sorry, I can't help you with your question..but just little off topic here...
Do you realize that you just compounded and exponentially increase the number of members named MIKE on this board???[&:]..It's mind boggling
Welcome
Their like rabbits! They just keep coming from everywhere.
Old Feb 10, 2007 | 07:29 PM
  #32
ORIGINAL: blackstangs281
ORIGINAL: Dennis
Welcome
Old Feb 13, 2007 | 04:21 AM
  #33
Xtreme's Avatar
ORIGINAL: HummBob
ORIGINAL: Dennis
Welcome
So that's how they make Easter eggs. Name:  7af892a4.gif
Old Feb 13, 2007 | 04:34 AM
  #34
Xtreme's Avatar
Default RE: Rattling/flapping noise coming from the windshield area
ORIGINAL: Calgary
RE: "The dealer R&R'd both outside pillar post covers, added some 3M automotive adhesive, and voila...problem rectified."
I have the exact same problem. Can you attempt to describe in more detail what the dealer did? Is the 3m adhesive a tape or a glue? Did he put the adhesive between the glass and the pillar cover in order to hold the cover down, or to absorb the vibration between the cover and the glass?
Any more information would be greatly appreciated!!!
Well, from what I was advised, the dealershipremoved the pillar post covers, added 3M automotive adhesive tape to the underside of each, and then re-affixed them back onto the pillars. BTW, after taking part in my dealer's'Hummer Happening' this past weekend in Borrego Springs, CA (which included some pretty rough terrain, as well as a tight steep twisty rocky climb to an abandoned Calcite mine) the pillar covers remained properly adhered, as subsequent highway/freewaydriving was still as quite as it was since the dealership rectifed the problem. Name:  3b824e7e.gif
Old Feb 13, 2007 | 07:01 AM
  #35
ORIGINAL: Xtreme
ORIGINAL: HummBob
ORIGINAL: Dennis
Welcome
[sm=happybounce.gif]
Old Feb 16, 2007 | 12:10 AM
  #36
Calgary's Avatar
Xtreme, thanks for the response.
When it finally warms up enough around here to go out and take those pillar covers off, I'll give that a try, and if it works, I'll post a detailed "How To" on the procedure.
Calgary
Old Jul 25, 2010 | 04:39 PM
  #37
hillbilly's Avatar
Default roof center console
what size bolts hold the roof center console up, i cant see in the holes. If I could remove it I think I could find my leak. It looks like all I need to do after that is remove the sunvisors to pull down the headliner enought to see if its my marker lights that are leaking.
Old Jul 26, 2010 | 10:25 AM
  #38
HumminNBoatin's Avatar
If you have a leak i would be willing to bet the water is comming in through your marker lights on the roof. Remove them and put down a small bead of rtv silicone and replace..
I am willing to bet your problem will be solved...
H2zona
Aug 6, 2018 06:31 PM
tunedin302
16
May 23, 2008 09:51 PM
tunedin302
May 22, 2008 03:18 AM
tunedin302
May 21, 2008 01:24 PM
HummerGuy
19
Apr 28, 2008 10:50 AM
